Activity Feed
Live updates
  • diambo4life replied to the thread Drag Race Build Project 98 Eclipse.
    · 127 15,285
    I completed the Saturn alternator swap this weekend using a Remy remanufactured alternator from a 96 Saturn SC I got from RockAuto. I tested the old OEM alternator and it failed and I had this new one tested and it passed. I used the same Jay kit...
  • Anfurnyy replied to the thread FIRST DSM STREET BUILD!!!.
    · 381 51,138
    These gaskets. They look great fit great but they always leak. I tried one myself from a Solo guy here (Aaron something or another?) and mine leaked real bad. You tighten it down too much and you'll bend your oil pan flange it will never seal...
  • diambo4life replied to the thread 1G Equivalent turbo advice.
    · 16 1,735
    There could be very many things wrong with your setup. Do you still have access to the stock MAF or EVO MAF? Use that as a baseline and get the car to run with it on the stock MAP so that you can eliminate 1000 other things being the issue. Do a...
  • Ludachris replied to the thread FIRST DSM STREET BUILD!!!.
    · 381 51,138
    Oh so close... stick with it.
  • diambo4life replied to the thread What did you do to your DSM today?.
    · 11,884 747,645
    Looks awesome Jason. What are you doing for fuel pump?
  • verified hick replied to the thread FIRST DSM STREET BUILD!!!.
    · 381 51,138
    i am so determined to drive this thing im almost ready to call a dsm professional to finish this stupid mf. i got the head back its 100% perfect holds 90psi on all the valves. he informed me of some thing like the bad hatching from where the...
  • diambo4life replied to the thread 2G Low Oil pressure.
    · 25 1,967
    That sucks man. Time for a rebuild.
  • explicitgst replied to the thread 2G Low Oil pressure.
    · 25 1,967
    Sad update... Drove it 40 miles yesterday, oil pressure at idle dropped to 0. Across the powerband I was down 10-12psi from my previous post. Dropped the pan, crank is walking. 😢 Welp. Guess it's time to build the spare 6 bolt I have.... Won't...
  • 97egl replied to the thread 420A Transmission swap.
    · 4 344
    PT Cruiser Transmissions are a direct swap, except the VSS may need to be changed IIRC. Finding a 2GNT replacement trans is next to impossible. I would just replace the synchro myself if it were me.
  • Justin DuBois replied to the thread ECMlink Global fuel wayyy off.
    · 152 12,429
    The "calculator" is just using theoretical math to make a good guess guess, but even the best theory cannot take into account all the variability in the system. Using ACTUAL measurements of the exhaust gas tells you what you need to do.
  • Atraea posted the thread '95 GSX Track Car in DSM Build Journals.
    This is the Build Thread for You must be registered to see element.. Reply below.
  • Atraea added a vehicle profile titled Road Race Build '95 GSX Track Car to the 2G DSM section.
  • VelocitàPaola replied to the thread 420A Transmission swap.
    · 4 344
    There are some Neon transmissions that will fit, but unfortunately the SRT4 transmission will not.
  • Anthony Hornback replied to the thread What did you do to your DSM today?.
    · 11,884 747,645
    You must be registered to see element. Installed an air cooled oil filter housing and had no oil pressure. I removed the housing last night and found out that it didnt have the relief piston or spring in it at all. Installed as piston and spring...
  • 2GbTalonGuy replied to the thread Interior guide?.
    · 2 242
    Carpet first, then dash, then your seat belts . Interior trim panels would be next and seats are last to go in. The door panels can go on whenever , but it’ll be a little easier if you don’t have to worry about them when the seats are going in.
  • Zanaqqq posted the thread Interior guide? in Appearance/Interior/Exterior.
    Since buying my 98 eclipse gst 5 months ago I picked up a full black leather interior for it. My current issue is the car only has the 4 seats, center console, headliner, and dash in it. No carpet, no door cards, no plastics. I have all new...
  • Ravewolf posted the classified ad Wanted ISO in DSM Parts Classifieds.
    Looking for a good or decent (not cracked in half or missing chunks) 1st gen driver side a-pillar trim
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 11,884 747,645
    She made it out of the garage for the first time in about 18 months for a bath :)Gotta wire up the 16v battery then it will be time for first startup.You must be registered to see element.You must be registered to see element.
  • Lhendrix52 posted a question on the classified ad For sale 1995 Eclipse GSX 600 AWHP Project/Parts.
    Location? Contact info?
  • stryker replied to the thread ECMlink Global fuel wayyy off.
    · 152 12,429
    @Justin DuBois - Sorry to revive this thread, but I've been trying to wrap my head around something I've been noticing that you specifically mention here and I'd love to hear more. When you mention the starting point for calculated global fuel...
