Activity Feed
Live updates
  • Aldo4b11 added a vehicle profile titled Street Build Daily RS 99 to the 2G DSM section.
  • Aldo4b11 replied to the thread 420A Window cranks stripped.
    · 1 208
    ebay? o yonkes
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 11,940 757,947
    No, a couple of the quickest DSM and EVO currently are running them.
  • CrackedDSM replied to the thread CrackedDSM's boring new project (420a).
    · 138 9,314
    That's the rear bracket, my brother in Christ. I need the front!But holy crap that is WILD! Like you said, loose bolts is how that happens? Jeebus.
  • rdeis replied to the thread 1G Clutch Bleed Secrets.
    · 12 1,083
    No, oddly. It got suddenly softer, but still had some pressure and would retract.I had done the same weld to the clevis/shackle as you to get more room for extending the shaft. That weld is what broke in the linkage. I believe that it...
  • Okay got the wheels and tires cleaned up and test fitted on the car. First off the rears definitely don't clear the trailing arm. I had to do a good bit of grinding off the "seam" or flashing of the trailing arm to keep both the wheel AND tire...
  • Well is hope not since it's a Fluidampr pulley. The little crank dowel is still intact and healthy as well.
  • dwb replied to the thread 1G Clutch Bleed Secrets.
    · 12 1,083
    Just so I understand the order of eventsclutch stopped disengaging and you found the master cylinder dry.Did the pedal fall to the floor and not retract?You replaced the master during replacing the master it was found some linkage was...
  • joshc replied to the thread 2G TSI AWD REPLACEMENT FUEL FILLER HOSE.
    · 7 3,955
    +1 HUGE help glad I took the time to dig, beyond grateful for your contribution to the community, my path continues :) 🫡
    · 12 1,083
    Found Jack's link from a long time ago:You must be registered to see element.A couple of the gurus here have mentioned that they don't like having the master adjusted as high as Jack says to here, but that video at least provides a test...
  • diambo4life replied to the thread Drag Race Build Project 98 Eclipse.
    · 127 16,069
    Got the ignition switch panel rewired, loomed and mounted. I may get a prettier panel down the road but this is working just fine. Slowly cleaning up the wiring. Over the weekend, I also sold the EVO wheels with the Hoosier DRs to make way for...
  • diambo4life replied to the thread What did you do to your DSM today?.
    · 11,940 757,947
    Very nice. Good luck with it and update us on how it performs. Are you the first to do this in a DSM?
    · 12 1,083
    Thx! Read paragraph 2, that's part of my standard procedure.The slave cylinder was manually compressed each time the bleed screw was opened, usually more than once, until there were no bubbles in drain line, then the screw is closed with the...
  • Ludachris replied to the thread ExtremePSI.com has a new website.
    · 16 3,106
    What are the main issues? I noticed you really have to use the filters now when drilling down to products for your car. The old browsing experience allowed you to choose a vehicle generation, which was nice. Now you have to enter year/make/model...
  • Christo replied to the thread Group buy: Stronger 5 speed gears!.
    · 79 14,730
    Last update I got was January.Hello everyone, It’s no secret that this project has taken longer than we initially hoped or expected.The refinement process for some components within the kit has required multiple rounds of rework. The most...
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 37 3,212
    Snapped a rotten bolt that was holding the radiator fan in place when I took it off/put it back on. Guess I'll have to drill it out and find a replacement, since there's only two bolts on it currently.Manifold is still off because I haven't...
  • tschuhly replied to the thread 2G Door side skirt.
    · 2 273
    It'll pop up eventually. Or call Kanapolis auto salvage in North Carolina which have a big dsm inventory.
  • steve replied to the thread General 1G ECU a bit toasty.
    · 3 294
    I don't know what the current conditions are for shipping across the Border but the people at ECMTuning are first rate with ECU repairs. You might want to let them look at both.I'll look downstairs are see if I have a good MD193299 just in case.
  • steve replied to the thread General MMCd-Go.
    · 5 496
    Looks interesting. While I do know C and have modified and build the MMCd Palm code in the past as well as helped disassemble the 1G ECU assembly code I don't know Go, Wails, or Svelte.If there are things your not sure about I might be able to...
  • dwdsm replied to the thread 2G Alternator Plug needed?.
    · 14 999
    Damn, Yeah all of that applies. Thanks Steve. Good thing I hid wiring in the new harness for it just in case. I think I should be able to DPO in place of the light/resistor tho and let Haltech do it's thing.
