Activity Feed
Live updates
  • dwb replied to the thread ForcedFour Time Capsule.
    · 37 3,220
    Can you get a box-end wrench on it to crack it loose then use an open-end wrench the rest of the way? You'll have to loosen and remove the other 3, and somehow separate the manifold from the turbo, either manifold up or turbo down, to get that...
  • jesse12345 replied to the thread CrackedDSM's boring new project (420a).
    · 138 9,335
    Man I've been super busy lately but I'm all caught up on this thread.Just remember if you do go turbo chances are your pistons are still stock and they will crack. I ran a couple runs at 20 pounds on a completely stock never touched 420a and...
  • Hey everyone. I've searched the threads using several different wording combos so I apologize if this has already been answered... Is there anywhere to find a front bumper emblem for a '96 model year? I'm not having any luck on google so I...
  • Eclipse_dreamer_PL replied to the thread Are 18's bad for 1gs anyone gotem?.
    · 18 5,188
    I know 😝 Do you know what rims I can install here?I do not know the current parameters of my current ones and they are so old and damaged that it is impossible to read the manufacturer's subtitles. The tyres I have are 205/50/r16.I want to...
  • shad0wsoda replied to the thread Crushed DSM's.
    · 68 6,945
    Here are two from the past year I've pulled a couple parts off around the Denver area. I REALLY should've pulled more off that spyder since it was a P88 car, same color as mine. You must be registered to see element.You must be registered to see...
  • We're on Boost replied to the thread 2G FIC 1440 HiZ Injectors.
    · 6 581
    1330 isn't very far off. My calculator number using FIC 1650cc injectors is 1495cc/min.For E85, your calculator number for stoic ratio should be 9.8 rather than 14.7. 9.8 there will give you a richer global number, and it would be the same...
  • Dsmguy97 replied to the thread 2G FIC 1440 HiZ Injectors.
    · 6 581
    I have done that and it does run decent starying point for idle and cruise but when I start tuning wot I run lean and my VE is already around 105 and have to add fuel way off of the global number suggested by the built in calculator on link. I...
  • jesse12345 replied to the thread Crushed DSM's.
    · 68 6,945
    If there 17s or even larger I'd straight up buy them! I don't want it to be a hassle though.
  • jdxnc replied to the thread 2G FIC 1440 HiZ Injectors.
    · 6 581
    If they came with the data card you should be able to enter that into direct access and zero your deadtime in the fuel tab.
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 37 3,220
    I have a bone to pick with whoever put a bolt underneath the headers of this exhaust manifold.I don't have any way to get it off because we barely have any tools in this house. I got 3/4 off from the turbo to manifold, but this last one is...
  • 92AWDHX40 replied to the thread 2G FIC 1440 HiZ Injectors.
    · 6 581
    Not yet il running 1440s to
  • CKOPOCT replied to the thread 2G paint.
    · 3 362
    Tough to tell from the pictures. All I can clearly see is the clear coat coming away. Do you have rust or issues at the wheel wells, strut towers, or normal wear areas? How's the front bumper? Road rash and rock dings in the hood? Etc.?If all...
  • Evannewell19 posted the thread 2G paint in Appearance/Interior/Exterior.
    how should I go about this? do I need a paint correction or paint repair or just a full repaintYou must be registered to see element.You must be registered to see element.
  • jdxnc replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,704 133,275
    Started de-winterizing my RV, first camping trip is only a month away....well it wouldn't start. Diagnosed it as no fuel, fired right up on brake clean. I then noticed the fuel gauge was about an inch past full..... We have lots of squirrels...
  • What about an inaccurate, or slipped balancer, then setting timing accordingly and the timing is now waaay off?
  • FIBA M - EC17PSE replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,704 133,275
    Likely is very HIGH! DOT and the US seem to say they care about you and the welbeing but fail to undersyand most drive around on zero tread tires and worn bushes.I find it highly amusing that the US can be so backwards in terms of the safety...
  • TerminalTalon replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,704 133,275
    People in Virginia complain about inspections. To pass Tires 2/32 Brake pads 2/32 Somewhat complete and intact suspension Lights work Defrost works Nothing can fail suspension wise that isn’t felt by moving a wheel(per the book) Normal=everything...
  • Dsmguy97 posted the thread 2G FIC 1440 HiZ Injectors in Bolt-on Tech.
    Has anyone has any experience with the blue FIC 1440 HI Z injectors? I cannot get my global and dead time numbers to look quite right. Followed spec sheet that came with injectors. Anyone care to share numbers on setup? Currently running a new...
  • Furiyous replied to the thread What did you do to your DSM today?.
    · 11,944 758,608
    Got my valve cover back from the paint shop and was about to install it today. Forgot to get the new half moon seal so now waiting on that. You must be registered to see element.
  • I have those fully loosened currently. I had taken all of them out at one point and had someone push the steering column towards the rack. It still wouldn't get down far enough. Did you have someone push down really hard on the column while you...
