Zeitronix ZR-2 Multi Gauge
I just got the ZR-2 Multi Gauge as an addition to my Zt-2 Wideband setup. I think the gauge is much nicer than the big box display I had previously.
Positives.....
The gauge is smaller than the display.
It is very thin and can be mounted almost anywhere.
Easy to read most of the time.
Can show me AFR, Boost, or EGT.
Negatives....
I didn't try to hook them both up but the instructions recommended against hooking up both the gauge and the display box. This is only a negative because you loose the peak-hold ability of the display.
EDIT: I didn't read the instructions carefully because I was in a hurry to play and it does have peak hold if you hold the button down for 1 second.
Overall impressions......
I really like the ZR-2 as it puts my AFR and Boost information in a more visible area for me (see pictures). The install was easy since I already have my whole wideband system installed. I would say that if you already have a Zt-2 Wideband then this is a cool addition that increases the visual appeal of the system. And if you don't have a Wideband then this is something to consider when choosing to buy one.
