Zeitronix with ecmlink
LOLVTEC
286
Dec 1, 2011
Los Angeles, California
okay i got a zeitronix wideband kit, and ecmlink.
my question is I'm going to run the Wideband sensor where the front o2 is located.
the zeitronix has an analog out put and a simulation output.
since I'm going to run ecmlink all I would have to do is connect the Wideband output to Pin#16? Pin #16 from my understanding is for logging the wideband to ecmlink.
or do i have to plug also the simulation output to the stock front o2 which is pin 4.
I'm so confused and don't want to mess anything up.
my understanding is just tap the wideband output to pin 16 and run narrowband simulation on ecmlink.
also when tapping the wire, do i just splice the harness or cut the wire and replace it with whatever I'm putting in that pin.
anyone i did some more research last night and found that since I'm going to run narrowband simulation through ecmlink, i need to replace Pin #4 on 1g ecu wiring harness with the wideband analog output.
someone correct me if I'm wrong or right?
