wtf ???
90blktalon
Feb 3, 2007
vinton, Virginia
Ok I'm at my buddies house and we are installing my pocketlogger and take it for a run. I DO A 2nd gear pull and the car dives off the road, i pulled back on the road off the throttle and the steering wheel is possessed, i pull into somebodies driveway and look at the axles and struts. seemed fine. turned around everything is fine. curiously i do another pull carefully and the same thing happens this time i stay on the road and let off the throttle and the tires were screaming. i just installed springs and kyb agx shocks and struts no problems till today. wtf?
I just opened this to say your title is the worst ever. If you read the print when you post a thread is says to be as descriptive as possible.
Anyways, did you align your car after install the suspension?
If you did, check the condition of your balls joints and tie rods.
Sorry about the title i was angry at what had happened i almost hit a telephone pole head on. Thanks for the prompt reply, i am taking the car to white tire to have the alignment checked.
You should be able to lift one side at a time and turn the tire side to side to check your ball joints, but suspension upgrades should always have alignment done.
Mike
