Would you use these cam gears?
  • Yes
    Votes: 2 13.3%
  • Maybe
    Votes: 0 0.0%
  • Never
    Votes: 13 86.7%
  • Total voters
    15
VETDRMS
340
21
Jun 1, 2006
Vancouver, Washington
I recently bought a set of "lightly-used" and "perfect-looking" cam gears. :rolleyes:
Nearly every tooth has some wear/damage and there are two large dents that have been filed down. Will running without a cover cause this kind of wear?
I just wanted to get some opinions on the useability of these. I will be running ~12mm lift cams with 350lb/inch spring rates with an OEM 4G64 belt.
Thanks!
nope, they will slowly wear your timing belt. I hate to tell you but those are the worst shape cam gears I have seen LOL. Most likely due to no timing cover.
Did you know they were in that shape before you bought them? You get them on here or ebay?
I got them from someone on the DSMLink forums. They were adverstised as lightly used, look and work perfect. The pictures included in the ad showed no damage.
I would do a claim and get my money back for poor description and saying that they look perfect. I wouldn't trust them it could affect the timing belt which is not good
