95EclipseGST
- 406
- 1
- Mar 1, 2002
Kansas City,
Missouri
I bought my 6bolt engine used on here and have spun 2 rod bearings so far. I just pulled the engine today and the rod bearing spun so much, there wasnt anything left of it and my piston had been tapping the top of the head. The head doesnt look damaged at all, but im taking it to get checked. For some reason, i have been getting seemingly bad oil circulation and i am new with engine internals, but im thinking the oil passageways and oil squirters are clogged and causing me to not get a good amount of oil and thus spinning bearings. I have metal shaving all stuck in my the oil pan, oil screen, and really everywhere. My crankshaft was damaged where the bearing spun out it looks like. I really dont have the money for this but i thought since this is my last time trying to mess with this car to get a 6bolt to run right, i should replace the whole shortblock with a new one with all new pistons etc. Since im a newbie with internals, can my shortblock internally be messing with proper oil delivery? The piston walls are fine, some slight scoring on the sides of the pistons beneath the rings. So i have a huge mess right now and absolutely need this build to come out right. Would you guys recommend getting a whole new short block, for the reasons listed? I was looking at a Stage 1 from SBR. Also i repeatedly kept getting Oil in my coolant. So im replacing my oil filter housing to see if it being crushed inside is the problem. Is it worth the extra $400 also to get a lightened crankshaft? Thanks for any suggestions.
