wont stay on
fng
Dec 20, 2003
yours, Washington
I got a 95 tsi and it wont stay on in low rps. I can start in and as long as I give it gas it wont die but if I let off i cuts off. I bought some stuff to clean the injectors ran it for 20mins and it does the same thing and im getting pissed off if i take it out of gear it dies and if I leave it in gear it wont die but if I push the clutch in it will die and win I let of it will come back anone know whats going on or had problems ike this or know some one who did
what is that ? where is it and how do I do it ad what does it do?
The BISS is circled in purple.
I got in intake on but what would that have to do anything ? where s that at I cant tell? I got the stock bov n I aint chaning that for a while
Is your bov being recirculated..cause if its not thats most likely y....mess with the screw to maybe that will help...but if ur bov is not recirculating then thats ur problem...plain and simple..unless u got standalone or gm maf or something to compensate for the air/fuel ratio ur frigging up...75% of dsms CAN'T recirculate..... :dsm:
i just need to know where it is so i can go fix it where is it at how do i find it :confused: :cry: and thankz for the help you guys are the best :thumb:
It is on the top of the throttle body. There should be a little black plug on it just remove that and you should be able to see the screw.
:thumb: I got it thankz alot I got it i got it ideling a little bit below 1g on the tack is that the norm ? one more ? do both fans come on when idel because only one came on when I was working on it :talon:
No problem there bro. The other fan turns on when you're running your a/c.
:talon:
