Won't start: Turns over, No spark, No injector signal
kc92awd
64
May 7, 2003
I am trying to get a 1992 turbo AWD 5-speed to start. Originally, it had spark but no fuel. Then I changed the clutch and now it doesn't even get spark. Is there a step in the vfaq clutch swap directions that can mess with the spark?
The starter turns the engine over. The fuel pump pumps fuel through the rail and the return line. The injectors are not receiving a signal to spray. I am completely lost. I now have no fuel and no spark. :(
check battery, make sure it's not discharged and loose. Tighten all connections. Check alternator, make sure everything is tight and secure. Make sure you have enough fuel in tank, check spark plugs, wires and ignition components. Then check if injectors are leaky or not.
Batter is charged fully and connections are perfect. Same with the alternator. Plenty of fuel. Brand new wires still do not spark. Injectors are not leaky. They just aren't getting a signal to inject.
I think I might just take the car to Mitsu because I have no idea what else to check.
