rab
- 41
- 0
- Jun 16, 2003
my turbo don't boost over 7 psi.
im running a .60/.63 t3 from a nissan 300ZX,before i ran a .42/.48 t3 with no problems.
i did a boost leak test and found a leaking comp housing gasket, fixed that redid a boost leak test and it
does not leak now.
im running a voodoo MBC and it working correctly, with the test i did, by pressurizing the system and watching the wastgate open, then adjusting the mbc and the gate open at a diffrent psi, so the mbc is good.
the turbo has none to little, in and out play and a little more up and down play but minamal.
how can i check if a turbo is bad???
also could i just keep the wastegate closed and go for a little run and see if it makes boost over 7psi,its not
really a good idea, but were should i go from here, any other ideas besides a bad turbo?
thanks
does not leak now.
thanks
