Wiseco Piston Ring Order??????
BoostedBeaver
Moderator
957
292
Aug 15, 2009
Augusta, Georgia
I just want to double check before I set My gaps. These are Weisco HD pistons with the XX ring set. Is the Top Ring Silver and the Second ring Is the Black one Correct???? Just want to make sure. Im setteing the gaps to 19 and 22 as well. Thanks in advance for clearing this up.
Is the top ring silver?? And is the Second ring Black???
XX
Ring Set
1mm (.039")
Alloy steel
Gas Nitrided
barrel faced
1.2mm (.047")
Cast iron
Phosphate coated
Taper faced
Napier hook
2.8mm (.110")
3-piece oil assembly
Stainless stl. fl ex-vent spacer
Gas nitrided rails
These are the instructions I recieved but just want to make sure I gap the right ring to the right place.
Well thanks for trying to help me out I stopped building it a few hours ago because I received 7 bolt pistons when I bought 6 bolt:banghead: :barf: I will get it straight when I talk to them on the phone.
They made it kind of idiot proof:banghead: The secound ring is thicker than the first ring therefore the second ring will not fit in the top ring grove.
My thoughts exactly.. They kind of only go in one way.. Just remember the sharp edge goes down! The instructions that come with the rings should show you pretty little pictures!
Yes, each ring set came with pictures and on my rings (1400 HD) 150 was printed on one side of the ring. This side of the ring is suppose to face the top.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
