Wiring problems
92talon720
57
Aug 15, 2005
Plattekill, New York
Well i rewired the 90 harness but there are some missing sensors that i need for my 92 engine and trans. reverse lights sensor is like non existant, and so is the throttle position sensor. I wired the ignition like it was explained on another site and that seems to work, i am just worried about the car not running well because of the missing sensors, i know i can rewire the reverse lights to a switch, but what should i do about the other sensors?
You need to get a hold of a TPS. The car will run, but it won't run right without it, especially if you try to go WOT.
Yeah i just got the connector off of my wrecked 92 talon, and i cant seem to find the wires in the harness...i dont know...going to try to run them to the ecu myslef, but idk what luck ill have with that
