wiring help
greenDSMdude
255
Sep 20, 2009
Binghamton, New York
i got some gauges that i wanna wire better, right now i got them wired straight to the fuse box and they come on when i turn the key but i want to wire them so they come on when i turn on my headlights where do i have to wire them to get this to happen?
does the stereo have a wire that turn on the illumination when you turn on the headlights. Would that work?
I'm curious to.....
well i got a different head unit and that comes on with the key. i just think it would be less "nig-rigged" if i took the time to wire it correctly instead of fuse boxing it. make it seem like i actually cared enough to do it right. :hellyeah:
just splice the wires that goes to the cig lighter light, not the cig lighter itself.
this will let you use the dimmer also, to get the gauges how bright you like em:thumb:
its what i did with my car, fairly simple and easy.
hmm sounds good ill give it a go.
wired it up this afternoon works great thanks 2gawdtsi
