wiring harness,which is which
spocks90talon
102
Nov 2, 2004
dayton, Ohio
when i bought my 1g talon the sterio wiring harness was cut, i having a lot of trouble figuring out which wire goes to what if anyone has a diagram showing what color wire is what it would be real usefull. thanks guys :talon:
This is the METRA/EIA Wiring Color Code I believe it is standard in most cars
Red-12volt Ignition/Acc.
Black-Ground
Yellow-12volt batt/Memory
Blue-Power Antenna
Blue/White-Amp Turn on
Black/White-Amp Ground
Orange-Illumination
Orange/White-Dimmer
Brown-Phone Mute
Gray-RF(+)
Gray/Black-RF(-)
White-LF(+)
White/Black-LF(-)
Purple-RR(+)
Purple/Black-RR(-)
Green-LR(+)
Green/Black-LR(-)
*Warning*
Some of these will not be used or present I am reading this from the back of a Toyota Wiring Harness but like I said I think most are standard colors to make it easier for all.
I am also assuming you are refering to the Stereo harness and not to the Under the Dash harness. If it is the Dash harness kill whoever did it because a stereo harness is cheap.
