winking pop up lights
hewhoisknot
743
4
Sep 21, 2003
Flushing, New York
so i changed the lights on my 1ga and i didn't get that shroud in perfect so the light wouldn't close all the way... i pulled the shroud out... but now one light is up and one light is down... and when i hit the button or turn on the lights it alternates between which one is up!!!!! i have tried manually cranking them.... but like if i crank the down light up then i hit the button to put the lights down the light will go down then come back up!!!!! and i tried disconnecting the motor wire... but it does the same thing... it'll go down then come back up!.... any ideas? i just wasted an hour on this!
hi hi hi hi...that must be a real funny sight..i bet you are gettin all the girls with that..i am goin to do it to my car too....be winkin when i see a girl....anyways..i think it is possible that you switched your motor wires..pull one out and reverse it see what happens.
i pulled on already... but i don't know how but even without power the motor realizes it was supposed to go up and once i plug the wire back in it'll do a double take... like go up and then back doen instead of just goin up..... grrrrrrrrrr
just pop the lights halfway up both of em, disconnect them from the switch and run the lights through the front plastic peice, it looks way better like that.
also my left front light wont even go up...it tries...like i can see the red knob on the motor spin but it just doesnt lift. so the right side comes up and the left side doesnt.
another question: how do you get the lights to just half way up so they look aggressive?
