2G Windshield Rubber Molding Replacement
RJ_IS_BATMAN
105
19
May 7, 2020
Ontario, California
Hey Everyone!
Was wondering if anyone knows where i can purchase a replacement for this rubber seal that goes around the windshield, its starting to lift on the 2 top corners of my windshield. I can probably just use some sealer/adhesive to hold it back down in place as the windshield doesn't leak but since im going through painting and doing the bodywork on the vehicle wanted to see if i could replace it.
^ This. When our windshield was replaced, the glass company had the correct molding in stock, and installed it. Because the gasket seal wraps around the edges of the glass, it may be impossible to remove just the seal without removing the windshield too.
There is some gasket seal overlap onto the surrounding body panels. If you are able to remove the windshield before painting, you will be able to cover all of the area around the windshield.
