window switch problems need help
99 E-klips gs
84
May 5, 2012
Wood River, Illinois
Got a 99 eclipse gs nt and I have been having problems with the driver door window working, it would work then it wouldnt. I would roll it down to go through a drivethru and then it wouldnt go back up for another 20+ minutes.. 2 nights ago it was rolled down and never wanted to go back up. stuck down now and cant get it back up. been hiding my car in the back of my driveway for 2 days because the window is down. Normally when a switch would stop working I could just remove the switch and take it apart and see what goes where and what wires work what, but my eclipse I cannot tell at all. No clue what wire does what.
a normal switch you connect 2 wires and it would roll up or roll down. but these eclipses apparently you need 2 constantly connected and then touch 2 more wires together..
I have looked and looked for a diagram of which wire is what on here but i cannot find anything. Does anybody know? All i want to do is roll my window up until i can get a new switch. thanks in advanced if you can help
When key is On:
The driver's Up button puts +12v on the windows green-red wire while the green-black wire is connected to ground.
The driver's Down button puts +12v on the windows green-black wire while the green-red wire is connected to ground.
  • Wanted 6 bolt NT water pipe
    • chrisman287
