will this hurt my engine?????
flipnotize
May 6, 2004
fayetteville, North Carolina
i js put a 50 shot of dry nos kit a couple of weeks ago. haven't sprayed yet.. i have a 95 rs.. with a aem cold air intake, obx header, obx catback, hi flo cat.. my question is will this hurt my engine if i spray it.. or will i be ok....? thankx..
do you have any fuel mods
nos is a fine way to add air to the engine but with air you need fuel and some form of monitoring your a/f ratio. 50 shot should be ok but the higher you go and the more you use it the better chance of running lean which is what blows engines. Also retard your ignition timing a bit, run high octane and possible use colder plugs. All these things are a good way to be safer.
how do u retard your ignition timing a bit?
