will this be safe to drive
davetheman81
163
Jun 16, 2010
randolph, Massachusetts
after building my car up with bc 272 cams, jmf race intake manifold and an fp green, i now realize i have a problem with dsm link and will have to send it out to be repaired, can i run a stock 1g ecu 1g maf on a custom intake pipe i made that fits the green, with stock 450cc injectors untill i get link back? or will the intake manifold and cams screw the car up on a stock ecu, stock maf and injectors
It will probably run alright. The idle might suck because of vacuum being pulled, but it should run ok in the mid range and wot. I would just take it easy and not drive the piss out of it.
ok i wont go nuts on it, but is it dangerous at all to have the 272s and smim on stock injectors, stock ecu and stock maf? i could also put in a stock ecu, with a 2g maf, and evo 560 injectors
Unless it is his daily and he needs to get to work for a week while his ecm link is getting fixed.
Yeah you can run it on the stock ecu with 272s for a few days fine. Just don't get on it hard. Drive nice and it will be fine.
