Will these wheels clear a BBK
Yeah they should be fine.. And I see your in OKC? I'm around there but I've never seen you around.
Sweet thanks for the info. As far as the okc, yea i am deff around. I dont drive my DSM much, i drive my other cars more. I am a Mod on OK-speed.com and Admin/co own theonepercent.net
Then hook me up dude! Ive been trying to get on OKspeed forever.. Its pending an admins approval or some crap
Doesn't the answer to the original question depend on which big brake kit you get? (Don't answer that; it's a tautology.) Is there a de-facto standard BBK for 2Gs such that original question can be answered? (That one you can answer.) If not and if people just like to grab the biggest brakes that they know use the same mounting points on the knuckle and have the right center-bore and bolt-spacing, then the answer could soon be 18"s if people start grabbing the front Brembos off an Evo X. The one bummer about trying to run an Evo X in stock autocross and rallycross classes is the need for 18s because of the front brakes.
One way to "test" whether a wheel will clear larger brakes is to see if people with stock Evos run them. What you need is that curve of the spokes. I know that the XXR 527 has a good curve to it, since people with Evo Xs run the 18" version with no problems.
I have two bbk. Stock evo8 calipers and a AEM Kit
^ i HAVE NO IDEA. BUT I AM ABOUT TO ORDER THE WHEELS.
Yep thats right... I work a ton, and the car is sitting. I have only seen the car once. I bought it, sent a buddy to go get it. If it was at my house, i would measure. But the HOA frowns apon broken down cars in front of the house or in the garage.
Ha, not shouting.. I use ADP in my line of work. And you have to use Caps. Sorry for that.
