Will these wheels fit
turbo4awd
206
Dec 19, 2008
Carlisle, Pennsylvania
Ive done alot of searching and for the 1g i found that a 27mm offset with a 17x9 is the best fit.
The Wheels i found are the 17x9 rota grids i can get them in a 30mm offset or a 25mm offset. Which would be best. id like to run a 245 width tire.
suspension is kyb gr2s with megan racing lowering springs. I would like to upgrade to megan racing coilovers aswell. but if i can get away with out them for now would be great.
Thanks in advance for the help guys.
27mm offset is optimal for your car, but not the best fit. The lower the offset number the more the wheel is pushed out away from the car. 35mm offset will fit the best inside the fenders and should work with the 245 tires, but 30mm is your best choice with those wheels. Spacers will not help you since you are already pushing the wheels out with low offset. With a 30mm offset at worst you will have to roll the rear fenders for clearance.
