will these lights work on a 1g?
You need to check to see if the size is right. It has been so long since I converted my I have forgot the size. Ours may be 4 X6". Call Advance and ask them for the size.
yea im pretty sure they're 4x6, does anyone know where to get some 4x6 housings that arent some cheap ebay ones, like some hella ones or something?
Get the atopal ones off ebay. They're just as good basically.
do you have them? because i heard some of the ebay lights dont put out good light
Err. I meant autopal. There are some people that have pics of their patterns online. It's one of the best besides bosh/hella.
The cheapest, cheesiest eBay Diamond Sparkly headlights will be immeasurably better than the seventies-designed sealed beam lamps. And they still won't dazzle other drivers, so long as you aim them properly- go up to a flat wall on a level lot and back up slowly. The cutoff edge of the low beams should just slightly lower as you back up.
Either of those will be terrific. Don't louse them up with queerboy blue bulbs. Looks like they have good prices on normal bulbs as well.
If you carry a spare bulb, you'll never need it. Witchcraft.
___
On Sylvania's site, it says the 91 Talon uses an H4666 bulb...those are made for H4656. What's the difference in H4666 and H4656 bulbs? And do you need a conversion harness or is it direct plug in?
Some of the later sealed-beams went to a plug that's |_/ instead of |_|, but there are adapters for them if needed. I'd doubt the eBay housings will need an adapter.
To use any h4 bulbyou need a conversion harness.
where do you get the conversion harness?
Search on ebay for 'H4 9003 HB2 Heat Resistance Headlight Wiring Harness KT'
Cheapest place I know. Autozone should have it too. I can get you the wiring diagrams later tonight.
My bad....so how is that conversion harness wired up? if its anything like the JDM lights I had for my Vigor, two wires go to one and the other wire goes to one...just not sure on the polarities of the ebay harness, which is + / -
