will these lights work on a 1g?
Wish there was a diagram on here that showed how to wire up the H4 harness to your stock harness. I'm sure you have to cut your stock connector off.
Do you have to take the bumper off to change the lights? I looked at them and there's a couple screws on the side of the popup part and there's screws on the inside, along the outter part of the light itself but there are some on the bottom that are behind something....part of the frame or the marker light.
I talked with the guy selling the Autopal lights and he said that you don't need a harness. That the factory plug will go straight to the H4 bulbs.
I also spoke with Racinglab about their KYO harness and they said that harness will plug into the factory harness and then into the H4 bulb...so I'm not really sure what to believe.
I totally forgot to take pics and put em up. I'll do that later tonight when I get a chance.
