will these injectors fit?
Darkmood
43
Sep 10, 2006
Aurora, Colorado
So a friend of mine knows a guy selling some Delphi 1000cc injectors for a great price, they came off an upgraded Audi A4. I currently have Delphi 660s. Will the 1000s fit my car?
they should fit, but u will need something to manage your fuel. for ie i use ecmlink. long as u have that u can put as big as u want.
Make sure they are Low-Impedence 2ohm injectors. As well as appear the same as your current 660cc
You will need some type of capable fuel management to compensate for these as said(eprom chip, DsMap, DsmLink,etc)
Delphi injectors typically need to be turned down in a lathe to fit the DSM rail, if I recall, so don't expect them to be plug-n-play. You may end up having to send them to FIC or somewhere else to machine them properly, and supply the correct grommet and O-ring to make them fit a DSM.
Also, they typically flow ~930cc, not 1000cc. Vendors like to exagerate.
Jeff O.
Cool, thanks for the info. I already have DSMlink to tune with so no problem there. No big deal if they have to be machined a bit, they were a good deal. Edit: and yes they are low impedence
