Dimensions on injectors...will these fit?
jking29
656
8
Jun 7, 2005
Huntsville, Ohio
Ok, I found a set of injectors that I can pick up cheap that have 2 hours run time on them. They are Siemens 55's and flow 599cc, and have 2.35 ohms impedance. What I need to know is if they will physically fit into the intake and fuel rail on my 1g turbo. I have included a blueprint of dimensions. I tried to find the dimensions on the stock injectors and came up empty handed. So if anyone could help I would greatly appreciate it. Thanks
Those are primarily V8 injectors. That I've heard of them before. They specialize in SVT, Cobra and SHO Ford products. You can only really by them in a pack of 8 so I highly doubt they will fit because of there length.
They are just a set of 4. You can buy them by 4, 6, or 8 at a time I know for sure. They came out of a custom Porsche turbo set up. I really need to know the dimensions on the stock injectors to know for sure if they will fit or not. Do you know for sure that they are a different length? Thanks
Is there anyone that has a pair of dial calipers and a stock injector that can PLEASE give me some measurements? I have looked everywhere and cannot find the specs for a stock injector. :(
I have a caliper here but no injectors. Have you tried contacting the manufacturer to see if they would fit.
