Will these coilovers fit?
Those are just sleeves man, they slip over your stock shocks.. They are cheaply made and suck DO NOT BUY THEM... Be aware that if you do buy them expect your stuff to break and be rough as crap while driving...
You are better off buying a spring/strut package. Unless you live in a dry, no salt environment then get the above. Once salt and weather reak havoc with the threads on the coil overs you will be hard pressed to get them adjusted.
