will non turbo shifter cables work on turbo fwd cars??
sonicnofadz
782
13
Sep 12, 2003
Baltimore, Maryland
I can get used shifter cables from 90-94 non-turbo DSMs for $5.00 a piece, which I rather do than pay $100.00 at the dealership. Are the 1G non turbo shifter cables compatible with the 1G FWD turbo transmission and shifter???
I would expect it to be the same provided they ised the same "model" trans in both. Being that the shifter and the trans are in the same locations in either the length should be exact. To make sure, I check with Mitsu for the part #'s.
Rich
VIVIDRACING :dsm:
as far as i kno they should fit im about 90% sure call roadraceengineering turbo trix or extrememotorsports to make sure
Wow thanks for the information guys! I'm just going to go to the junkyard and pull off a set from another 1G (91-94) for $5.00. I'VE BEEN SAVED FROM SATAN!
