Will I need a bigger turbo?
Also, what kind of fuel pump do you have? 190lph or 255lph? Depending upon which one you've got, you'll need an Air Fuel Pressure Regulator.
And as far as tuning goes, you need to have something for them to tune it with.
Uhhh....you car should already have an ECU in it. If it doesn't, it wouldn't start up and function.
Correct. You can pull the ECU and send it in to the guys at ECMLink and they'll chip it for you. When you fill out the info you can enter in that you've got 750cc injectors as well, and they'll set it up to run them right away.
Pulling the ECU yourself is not very hard at all. If you can afford to have the car down for a little while, you could pull the ECU yourself, send it in, and while it's in, install your 750's so you're read when the ECU gets back to you. A shop could do all this for you as well, but you'll definitely pay more for it.
It's 4 bolts to remove the ecu vs god knows what the shop will charge. Contact ecmlink directly for how much it would be to socket your ecu plus the cost of the program. Or maybe you can search the classified's and buy a ecu with the chip already installed and save your self the down time.
Do not put those parts in your car until you have everything lined up with your tuning software and where you are going to be tuned at. You cannot just add those parts and drive your car as if it would be normal.
I think you need a little more understand of these cars. I would do alot of searching and get more knowledge on how these cars are and understand modding them.
How much would a shop charge ya think? And how much if I took it out and sent it off?
make sure your ecu is an eprom ecu first of all, only year 95 for 2g's come with eprom. that's roughly 200.00 and with ecmlink installed/chip, another 495 on top of that. when you send your eprom ecu to get it chipped, they'll send you a cable to hook up to your' OWN laptop along with your chipped ecu, then install all your parts and have the shop tune it, for your own good.
dsmlink.com. it'll tell you what you need to get dsmlink.
