Do I Need Bigger Injectors?
750cc will support 43lbs/min at 80% IDC according to the injector calculator. So on pump gas you'll be cutting it close.
I was 100% maxed out on my WH1c with 750's and made 450whp on E85. I doubt you'll move that much air on a td05h-20g. Your idc's will be high but It'll be ok. If you wanna go harder you'll need bigger ones for sure.
Currently, I have the same turbo with 650's. I don't know my idc's yet because I don't have link installed yet, but I'm running pig rich at wot even at 20psi, and that's with no knock.
