Will heavy fuel cause a no start?
preludeachris
295
3
Sep 29, 2011
Lincoln, Nebraska
So Im trying to start my newly rebuilt motor and I just cannot get this thing started. It acts like it want to try to start but doesn't I Know I have spark. The only thing that comes to mind is fuel. The gas thats in the tank is about 11-12 months old. I added lucas fuel cleaner and 5 gallons of fresh new gas, I did a fuel gravity test and it still tests way on the heavy side. Is gas my issue or something else? I have a factory fuel pump (which DOES run) with 850cc injectors and MXTL wideband.
Have you check your grounds? I had issue like this the other day. Car cranks and all but wouldn't start. New ground and bam. Engine starts.
Make sure fuel is getting to the rail. Most likely after sitting there for a long time something clogged up.
EDIT: the filter loves to clog up on our cars, replace it.
I already put in a new filter on it.
Can you elaborate? New ground??
When I rebuilt my motor, after sitting for a long time I sent my injectors off to be cleaned and flow tested. To my suprise 2 of them had 0 flow and the other 2 only flowed 50%.
Sitting for long periods can make injectors not work. Take rail off with injectors and see if they are spraying a good pattern.
OK UPDATE;
I Now have the car running :D BUT its running VERY poorly feels like its missing....My problem was spark plug wires were switched around I thought the numbers on the coil packs ment which cylinder it went to ...I guess its not?
I dont know if its the new cams or what but its running REALLY rough tips would really help me out thanks!
ok heres a log of it at idle it seems to struggle to idle and thoughts?
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
