Will EVO8's fit?
No...
Not directly...
You will need to fabricate a bracket to mount the caliper off of the eclipse caliper bracket.
Look at an AEM big brake install and the plate they use... Like that but drilled to match the brembo's off the evo...
dude $500 bucks for all four corners. pads, calipers, rotors, lines... everything. Only used for about 1000 miles.
Carboard template of the plate he made..
VR4 Brakes
Same concept just different calipers....
Links and pics aren't working. What material would I use to make these brackets? I wouldn't wanna make them and it break. That wouldn't be too good LOL. I can cut metal, my uncle owns a bodyshop.
OK I took a pic of an article on a big brake install on a 240sx in the march 2003 edition of HCI. I will have to fabricate the red piece in order for the evo brakes to fit, correct?
No I didn't. I did get 4 piston calipers and rotors from a vr4 300gt (only the fronts), I fabricated a mounting bracket and they will be on shortly. Pics forcoming. ;)
Sounds good.
Either way a cheap 4-piston setup is a cheap 4-piston setup. :D
Can't wait for the pics.
I painted them red, but they are in my dads garage or I would take pictures. I have this picture I took a while ago. I might throw some "brembo" stickers on them for good measure. They are only like 10 bucks on Ebay. Sorry about the lighting. :|
Cool, I'll check ebay later.
Definitley want impressions once you get them on.
    • george bromwell
    • pma1123
    • Sdcryan1
