Will Evo rotating assembly fit 7bolt 1g 4g63?
vicore
48
Nov 9, 2012
Berlin, Europe
Have an offer of an stroker rotating assembly which is told to fit evo 4 to 9 and 1g +2g 7bolt engines.
Kit:
100 mm mitsu crank
crower rods
wiseco pistons
Is it correct? I'm sorry but I couldn't find a fitting thread. As far as I found out, there are different part numbers for the dsm and evo cranks.
Hope som1 can help me out here :hellyeah:
It should fit. Stock dsm crank is forged while the stock evo crank isn't forged. I think dsm is 35 pounds and evo is 30 pounds. Since your going to the 100mm stroke crank its just a 2.4l crank 7 bolt crank is a 7 bolt crank doesn't matter evo, 2g, 3g, etc.
ALL 2.4 whether Mitsu or Hyundai take same rod and main bearings so they should interchange, crank registers are the same, so it looks as Hyundai elected to go 6 bolt on the flywheel end, WHY?.
No I'm pretty sure the hyundai 6bolt fits.seven bolts and not six bolts. Ill reconfirm.from my books later.
Umm what? I have a G4cs block and 6 bolt crank. The 6 bolt cranks do not fit in a 7 bolt block. 7 bolt cranks don't fit in a 6 bolt block. They are not interchangable. More facts
100mm is 2.4 crank 86.5 is bore
88mm is 2.0
100mm crank in a 2.0 block is a 2.3
88mm crank in a 2.4 is a 2.1
If you don't know the answer search.
He has a 7 bolt 1g block, not a 6 bolt 1g block.
The 2.4 crank is a 2.4 crank, be it in Hyundai or a Mitsu.
He never mentioned a 6 bolt BLOCK.
Yes the 7 bolt 2.4 crank will fit in a 1G 7 bolt. 7 bolt cranks are 7 bolt cranks don't matter the yr.
I was referring to the nonsense MJcanada was smoking. That 6 bolts fit in 7 bolts.
If you read correctly I only thought the g4cs 6bolt was swapable. Which was a simple misread on my part. Your spouting facts already known. i know the answer thanks I've been searching for years and said I would reconfirm. and I reread and found iread it wrong. Thanks though.
Okay thanx for that hot discussion ^^
I'll try to go with the stroker then.
I've just another more or less related question, are there two types of 4g64 cranks? Cause i found 4g64 cranks and 4g64+4g69 cranks. How is it?
They are both 100mm stroke
69 just has a sohc head with mivec and 87mm bore
  • Wanted 6 bolt NT water pipe
    • chrisman287
