Will Coilovers from a FWD eclipse fit an AWD?
CR1MSON FURY
Jun 10, 2005
N0VA, Virginia
I was wondering because my friend has a GSX and he wants to install Coilovers that are from a FWD GS. So will this work or is there anything else he needs to do?
An AWD turbo weighs a lot more than a FWD non-turbo, it will lower it even more on the AWD then the FWD. It won't have a correct spring rate.
They'll be fine, being coilovers you'll want to have a grinder handy though to grind down the silver ring on the strut.
if they are those cheap ass coilovers OBX etc.. then they are the same for all Talon/Eclipse models. They didn't make them any different for the n/t vs. the turbo. Ground controls are different and you wouldn't wanna mix them but the other ones are all the same
Hell those cheap ass manufacturers share as many parts as possible. The Ingetra kit shares the same spring as the DSM kit does and they are completly different, only the perch is differnet. THey are brutal.
