2G Will a '97 GS hatch fit my '97 GSX?
Yes. Youll only be stuck with an empty middle hole if you plan on using your high rise since the low rise has 3 mounting points I believe.
Solution
Correct, low rise has three points from what I see.
I found a clean GS hatch that's also Magenta Grey pearl, think I might take it and just throw a grommet in that middle hole then.
Thank you!
