Will a 96 bodykit fit on a 89?
1gen2genLaser
49
Oct 10, 2004
Canton, Ohio
This isn't a dsm ? .. but this si the only site im subscribed too.. Is it possible, to take a 96 S10 bodykit and cut/mold it to a 89? If anyone has ever done it, or know if it is possible, please post back.
Thanks. :laser:
Yes it is possible and more than likely you will want to chose a fiberglass body kit if you do it because they are alot easier to work with than urethane. However if you don't chose a bodykit that matches the body lines and the boxiness of the older s10s then it MIGHT look bad, this would all be your opinion though. It isnt that hard just play around with fiberglass and don't make a body kit mod your first project with it. good luck :thumb:
