Will a 90 turbo fwd MT, fit in a 93?
Doubletake
92
Nov 21, 2002
Winnipeg,
I am kinda needing to know this, my auto tranny is acting up (only upshifts at 3500 RPM, hard shifts too) an i was gonna do a Mt swap anyway, i found a decent turbo 5 speed from a 90, is there anything different about that year? when comparing to a 91-94?
I already have a 6 bolt block i swapped in, that i plan to convert to turbo eventually.
Thanks
Ok, i looked around and did a bit more searching, I found that the shifter and cables i have are from the 90 style. This means that the whole setup will be a match and should work.
Now my question is will a flywheel, clutch and pressure plate from a 91 AWD manual transmission be compatible with the 90 FWD manual transmission, both are from a 6 bolt, so the bolt-up is no worries. Just will it work inside the tranny.
One more, i read the tech on the tranny conversion and it says nothing about a switch from the AT starter to a MT starter, is it really needed?
Thanks
Matt
I believe the clutch and pp have different part numbers.
Most people say that the flywheels are not interchangable but a friend of mine said he put an awd flywheel on his fwd with no problems.
That switch sounds like it may be the clutch start switch, nothing major, just don't start the car in gear without the pedal down.
