will 265/40's fit on a 2g?
14.5 drift said:
If so wich rim would they fit the best on, 8 inch or 9 inch wide rims? Offsets?
If you don't plan on lowering your car much and dont mind having the wheels stick out(more than likely), yeah. I would say 265s are a bit much for an 8" wide wheel as well.
forgot to mention they will be going on 17 inch enkei rpm2's........
and to spidey, no I dont plan on lowering the car much at all. I sort of like the front stock, and i think I want to lower the tail end to even things out a bit. I might be willing to lower an inch in the front, but no more than that.
Screw it, I can't even find a 265 that i like .......... how about 255's on an 8 inch wide?
8 inches is a little narrow for a 255. You will need an offset of 35mm or less and they will stick out a little so you won't be able to go too low with your suspension.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
