Will 20" x 8,5" wheels, Offset 34, fit my 2G?
perle
May 11, 2010
Norway, Europe
Will 20" x 8,5" wheels, offset 34, fit my GST 1996 2G?
Eclipse Turbo OE:
89 - 97
16x6
5x114.3
offset: 35 to 45
67.1
No...anytime you ask "does this wheel fit" you need a few items. Rim height, width, Offset (distance from center), and lug pattern. Tires will also play a role in this. I cannot personally tell you if they will fit or not, but for those who CAN help, give them the offset.
Ok...I'm going to assume you just didn't type this in correctly, and it SHOULD read, 20x8.5 -34? if so, -34 would be the offset. If you don't HAVE the offset, search your rim and find it. The interwebs have all the info you would ever need, from porn, to cooking, to rim size, to photos of your great grandmother. If you want help with your wheels, and your serious about it...type it correctly and provide all the info so people can actually help you.
LOL...I was thinking it, but didn't want to crush the kids hopes...I mean, in all honesty, you can put 24s on an eclipse...just kiss your fenders goodbye...along with the way your car looks and rides.
I remember the dub'ed out eclipse on NFS...looked hot. I however wouldn't do it unless it was for show purposes only. I imagine the ride would be horrible! I did have a friend that had 20 inch Konigs on a 3g and it looked hot...however he was replacing tires left and right due to Chicago Potholes. I don't knock your idea...but give it a strong thought. 18's and a decent drop will produce the same results!
Im going to say no. You will have huge issues in the rear. My 18x8.5 38offset barely fit with the tires on. I mean i have only a few centimeters. Its crazy tight.
See, the guy in that page was running tires not size for that rim. They were stretched. I can somewhat believe it with also that huge backspacing too.
