wide-band reading??
xxAfflicti0nxx
Dec 12, 2011
shirley, New York
i have a glo-shift wide-band gauge and now my wide-band is reading [3]...
i have no idea why, can someone help me? :confused:
Can you give us some more information.
Did you have any A/F gauge before?
Do you have a Wide-Band o2 sensor installed?
no its been the same gauge since ive bought the car, the gauge was working perfectly fine...
then my flew pipe broke. the gauge was still working fine after that; until i few days later.
now it reads [3] and sometimes [4]
Here's the manual: http://www.glowshift.com/instructions/Digital-Series/GS-D02W-Wide-band-AirFuel-Gauge.pdf
Error code 3 is a sensor error. Check you connections, if it's all good hold the button on the gauge for 8 seconds to rest it. It should display 4 the 2 and reset. If it goes back to reading 3, the sensor may be bad or the wiring is. It's on page 2 of the manual, with the tech support number. Hopefully it just needs to be reset. Good luck :)
thank you :thumb:
and yeah i ment flex pipe, sorry spelling error:ohdamn:
thank you :thumb:
LOL that's okay. I was genuinely concerned that you thought there was a actual part on your car called that and thought the problem was gonna be much tougher.
Have you fixed your flex pipe yet? If it's leaking you're probably gonna get bad readings on your A/F Gauge even after you reset it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
