Why does it take 5 minutes for my idle stablize?
squid267
158
3
Jan 14, 2012
Dallas, Texas
Curious why it take my idle awhile to stablizes. It starts at 2k and slowly comes down to 1k.
FIAV Blocked off.
ISC set correctly.
No boost leaks.
Any ideas? Its not a huge issue but I don't want it to become an issue.
Since you have the FIAV blocked off the valve stays open longer , no coolant is passing through the lines. Your car will take a bit longer to idle better.
It's just like Phantom said.
The way to adjust this properly is to tune the ISC coolant maps.
Do you have a way of tuning your ECU?
The FIAV was blocked off when I bought the engine. Had no idea what it does. I have ECMLink v3. Can I use that to tune the ISC coolant maps?
Oops my FIAV is not blocked off my EGR is.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
