whos running water-to-air?
garage16
133
Oct 4, 2008
toronto,
Just like to know whos running a water-to-air set up.
I wanna see pictures of what you guys use as a ice box
thanks
I saw a good setup the other day. It was a water to air setup with a removable plate ontop of the intercooler that allowed you to pack it full of dry ice when you are at the track. The inlet air temp was around 40degf with a track temp of 77deg.
Looking to grab a Air to Water Radiator for drag racing and seen this stuff
Anyone using it or seen feed back? also do you use it with fans?
thanks
That piece there is a radiator. You'd probably be better off with something from the junkyard or a motorcycle piece. My friend is using a big finned transmission cooler. I'd been planning on using the AC condensor, but I don't know how that will work.
