Who sells the smaller Evo Oil Squirters ?
Black94DSM
815
27
Jan 17, 2006
Madison Heights, Michigan
I'm looking to buy some evo oil squirters for my 2.3l. The stock squirters hit the pistons and I just dont like the idea of bending them out of the way(possibly breaking them). I dont want to block them either.
So who sells these besides dealer?
Also does anybody have any pictures of them? I would like to compare them to the stock oil squirters to see if they will be a better choice.
Worse come to worse I will block them.
Thanks,
~Bob
Solution
I just installed the Evo Squirters in my 2.3l block with Wiseco Pistons.
The squirter will bolt up without a problem but it hits the inside edge of the piston as seen here.
What I did to make this work was just bent the tube 1/4 inch upwards towards the piston pin. Here is a picture of the Modified Evo Squirter.
Everything went together much easier with the Evo Squirters. They make a much better starting point.
Hopefully this helps you guys doing the same thing.
Bob, not sure if youre still open to suggestions, but I have had good luck just bending the stock squirters to clear my Wiseco pistons. They are actually not as fragile as they seem.
Just my $0.02
It seems every way I bend these darn things they hit either the piston or the crank counter weight.
I would like to see how small the evo aquirters are in relation to the stock 1g squirters. Anybody have pictures of the evo squirters ?
I'm seriouly leaning towards just blocking them off.
Solution
    • george bromwell
    • pma1123
    • Sdcryan1
