Who runs a bullseye housing w/ garrett turbo, how does the wastegate actuator fit?
Verticaljump1
147
May 8, 2004
cheyenne, Wyoming
I'm looking to buy the DIY bullseye turbo kit for a garrett turbo, but Idk how the wastegit is going to fit the mitsu style housing, tips or pics are great, thanks guys.
I have an AGP RS49/50 trim with the bullseye turbinw housing. The actuator for the interbal gate attaches to the 02 housing and is on an angle so that the actuator arm is on an angle also. I bent the very end of the arm that fits on the flapper arm and it fits a bit better but I am afraid if I bend the end any more it will snap off. I have tried bending the actuator's support but still cannot come up with a good angle for th arm. I will try it again as I am replacing a blown gasket. mark
PS: This has not caused any problem so far but may shorten the life of the actuator's diaphram.
@nd PS: Upon closer inspection all I have to do is slot the hole where the bolt holds the actuator to the 02 housing and it will line up perfectly! Mark
