Who has done the Peepers WGA Mod?
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
Been having trouble with my boost levels as of late. I believe it is due to the actuator not opening as it should. I posted a few videos in a different thread. But, was wondering if anyone has done the Peepers WGA Mod?
I dont really have the time to do it myself, my work schedule is hell now that the "holidays" are here. If anyone has done it, I am willing to send you a brand new actuator I have and pay you to mod it. PM me?
Also, could 272 cams cause it to creep up to and past 20psi? I just have the WGA hooked straight to the j-pipe right now and it still shoots up to 20+
I had it done. It helps yes, but if your exhaust housing isn't ported it probably isn't going to get rid of your creep. It's more meant to work hand and hand with a ported housing. I had a particular bad case of creep and that and porting got it under control.
It is already ported. 7cm inlet, ported wastegate, 34mm flapper. PR Atmospheric O2 dump, Evo 3 manifold
