whitish smoke
Hectorb25
74
Sep 16, 2011
miami, Florida
My 95 gst is blowing white smoke from exhaust sometimes when I break , shift and accelerate.
I have a boost controller on the car and when I moved it to mess it around with it , it got worse as I stated earlier , I honestly think its a blown turbo any other suggestions ?
What rings can be bad ?
Piston rings.
Do a compression check as a starting point, go from there.
edit; If your compression is low in any cylinder, put in a few teaspoons worth of oil. Repeat test. If numbers are much higher, piston rings are worn or damaged.
Check your oil to see if you dont have water in it, if uou do its possible your head gasket is gone, does it smoke at idle too? I'll say its most likely your valve seals
