420A White smoke from exhaust?
SXYDSM
45
Dec 20, 2015
Springfield, Missouri
I got white smoke out exhaust of my 96 RS thanks for the forum
Do a leak down for sure, I did the results were pulling the head for a valve job and of course a slight leak in cyl 3 hg, good luck
Do a what? Sorry I'm learning mechanics and engines right now
You can do a cylinder leak down test to see if you have bad a valve leaking a bad head gasket. You use a tool that hooks to an air compressor and puts air in the cylinder and has two gauges and you look for differences in the pressure. It's hard to explain but there is a good video of it on YouTube. When is your smoke primarily?
shouldn't be an injector stuck open. coolant is white, so is just condensation in the exhaust, blue is oil and a fuel injector stuck open would be black smoke. its not always going to smell sweet coming from the exhaust being deluted by the burnt fuel smell. a leaking head gasket won't always blow between 2 cylinders to. it can blow between a cylinder and coolant channel or oiling channel which could burn oil or coolant. a way to test this is by a leak down test. looks like a spark plug base that threads in but has a hose on top. put it in each cylinder 1 at a time. take the coolant fill cap off and oil fill. put some pressure in the cylinder. now, look for bubbles coming through the cooling fill neck. take out the spark plugs to the sides of that cylinder and see if it loses any pressure between the other 2. either way, bubbles in the coolant is a blown head gasket
I just have white smoke coming out the muffler when it's running.. but the inside of my window keeps following up and I had seen coming out dash.. now I'm trying to get my dash out to get to my heater core... funny thing is this is another used engine my first one was also blowing white smoke really bad
The inside of my windows keep fogging up and I had steam coming out the dash
Yea defitly sounds like you could have a pretty Leaky head gasket on your hands, the leak down would reveal that.
Just another note if you smell the steam coming out of the exhaust and it has a sweet smell to it that's more than likely the product of burning antifreeze.
ditto on the leak down test but with basic mechanical skills i would just start with a compression test. it only takes a few min and its as easy as changing a spark plug. if it ends up having low compression then there ya go, if not then you have other tests to continue diagnosing.
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
