Which would you choose and why?
Whicch would you choose for this scenario?
  • 8.8:1 = .070 thick gasket.
    Votes: 10 76.9%
  • 8.6:1 = .075 gasket.
    Votes: 3 23.1%
  • Total voters
    13
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
So if you were building your car and only had:
93 octane
50-50 meth
Holset turbo and wanted around 25lbs
Ecuflash and evoscan to tune
Build motor
And were using a .020 Cometic MLS headgasket.
What compression would you pick and why?
8.6:1 = .075 thick
8.8 = .070 thick
I prefer to use a thinner gasket, as there is less force that can be exerted on in.
What holset turbo? The bigger, the more pump gas freindly obviously. I see no reason at all why a properly tuned motor would have issue at 8.8 w/ meth. Stocks 8.5 of the 2gs.
My votes for 8.8:1
