Which used parts are compatible?
bennettn56
Mar 11, 2013
joliet, Illinois
92 eclipse gs with the 4g63.
Looking to buy a valve cover
Mass air flow
Idle air controll
Throttle posistion sensor
I'm asking because ebay and junk yards are not going to be very helpful on what will work.
Mainly, which valve covers work?
Any valve cover from a 4g63 will work. I have one from a 6 bolt on my 7 bolt right now.
The other parts im not 100% on since its not a turbo model. Hopefully someone else will chime in
Any valve cover yes will work as long at its a 4g63.
Mass air flow sensor has to be from a n/t since a turbo model has a 7 pin plug and n/t has a 6 pin plug. I beleive but not for sure that the throttle position sensor can be from either a turbo or n/t.
And also not 100% sure but the idle/air control can be either or as well. You can also always call your local auto parts store and they can see if the part numbers for each are the same or dif. If there the same fro a n/t to a turbo mofel then your good to go.
If they are dif from a n/t to turbo model then there not compatible.
Hope that helps out.
Mass air flow
Idle air controll
I have a Mass Air Flow from a 1g n/t, used but works. PM me if your interested. and I can send yea pics or anything you may want.
