Which fobs are compatible with 1998 eclipse spyder?
rolltidero
319
24
Jan 9, 2014
Madison, Alabama
I recently found out my 1988 eclipse spyder gst has remote/keyless entry. I need to order a fob and I know how to program them. I was wondering if any other fobs or remotes are compatible like a newer eclipse remote. I just want I avoid paying $40+ for one from a dealership.
Not that I know of, any different key fob that is going to work will cost some money. $40 isn't to bad for a key less entry.
Our dealer could not longer get the ones for our '96 Talon, so we ordered from remotesandkeys.com, and $28 later, we had two remotes. Programming takes 2 minutes and a paperclip.
I just got one off of ebay for 30. What I just did was call the dealer and got the part number for the remote and looked it up online to get the FCC ID#. I don't know if they are the same numbers for you but you can call the dealer and they will give you the number that you need.
Edit: part# MR123944 FCC ID# GQ43VT6T
So the Dodge/Chrysler remotes would work?
That's the part number that the dealer gave me. Just call up the parts department and ask for the remote part number for your year spyder. They should give it to you and then look that number up for they FCC id # . I typed the FCC# into ebay to get mine.
